Displays the available routes to the specified IPv6 address.
| ipaddress | Specifies an IPv4 address. |
| ipv6address | Specifies an IPv6 address. |
| unicast | Displays the routes from the unicast routing table in the current router context. |
| multicast | Displays the routes from the multicast routing table in the current router context. |
| vr_name | Specifies the VR or VRF for which to display the route. |
N/A.
None.
The following command performs a look up in the route table to determine the best way to reach the specified IPv6 address:
rtlookup 2001:db8::ef80:2525:1023:5213 unicast
The xhostname option was removed in ExtremeXOS 11.0.
Support for IPv6 was added in ExtremeXOS 11.2.
The unicast and multicast options were added in ExtremeXOS 12.1.
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
